Ga door naar hoofdinhoud
Weinmann VENTImotion and VENTIlogic Power Board Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
  1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: stap 1, afbeelding 1 van 2 Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: stap 1, afbeelding 2 van 2
    • Open the Device by following these steps:
    • Open the device only with the power supply plug disconnected.
    • Place the device on a non-slip surface with the top facing downwards.
    • Remove the filter cassette from the top part of the housing
    • Undo and remove the 6 screws (34)
    • Open the bottom part of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43)
    • You can now put the bottom part of the housing (35) to one side.
  2. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 2, afbeelding 1 van 1
    • Disconnect the power board connecting cable (45) from the power board (41).
  3. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the Motor Cable
  4. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the O2 valve/power board connecting cable (70) from the power board.
    • Disconnect all connecting cables from the control board.
    • Remove the power board from the top part of the housing.
  5. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 7, afbeelding 1 van 1
    • Take the rechargeable battery connecting cable (48) out of the groove and disconnect it from the power board (41).
  6. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the cables of the old power board and plug them into the appropriate slots of the new power board 41:
    • –power board/control board connecting cable (46)
    • –rechargeable battery connecting cable (48)
    • –earth cable (47)
  7. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 9, afbeelding 1 van 2 Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 9, afbeelding 2 van 2
    • Connect the power board/mains supply unit connecting cable (45) to the new power board.
    • Position the new power board in the top part of the housing.
  8. Weinmann VENTImotion and VENTIlogic Power Board Replacement: stap 11, afbeelding 1 van 1
    • Restore the connections to the control board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emily Jacobson
288 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G19, Paton Spring 2020 Lid van Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 118
