Ga door naar hoofdinhoud
Water damage
  1. Water damage, Disassemble the primary frame: stap 1, afbeelding 1 van 2 Water damage, Disassemble the primary frame: stap 1, afbeelding 2 van 2
    • Use a piece of plastic, like a credit or store card, to open up the case.
  2. Water damage, Detach the secondary frame: stap 2, afbeelding 1 van 3 Water damage, Detach the secondary frame: stap 2, afbeelding 2 van 3 Water damage, Detach the secondary frame: stap 2, afbeelding 3 van 3
    • Lift the cover with a plastic card and carefully pull it off.
    • Tip: The glue is very strong, so I recommend helping things along with the plastic card.
    • If you remove the cover slowly and don't stick the plastic card in too far, you might be able to re-use the strip of glue.
  3. Water damage, Detach display and mainboard: stap 3, afbeelding 1 van 2 Water damage, Detach display and mainboard: stap 3, afbeelding 2 van 2
    • Loosen the seven 20mm T5 screws.
    • Then slide the display upwards.
  4. Water damage, Disconnect the battery: stap 4, afbeelding 1 van 1
    • Now the battery can be disconnected and replaced, if necessary.
  5. Water damage, Detach the display cable: stap 5, afbeelding 1 van 1
    • This Kindle has water damage which corroded the display cable.
    • I think changing the display is not possible because it is glued to the mainboard, possibly even soldered. I won't try replacing it because I only need to clean the display connector.
Conclusie
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Lukas Wolf
121 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 709
