Ga door naar hoofdinhoud
Water Tank Sealing Replacement
Wat je nodig hebt
  1. Water Tank Sealing Replacement, Jura Impressa Type C E F opening procedure: stap 1, afbeelding 1 van 1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Water Tank Sealing Replacement: stap 2, afbeelding 1 van 3 Water Tank Sealing Replacement: stap 2, afbeelding 2 van 3 Water Tank Sealing Replacement: stap 2, afbeelding 3 van 3
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Water Tank Sealing Replacement, Lift support: stap 3, afbeelding 1 van 2 Water Tank Sealing Replacement, Lift support: stap 3, afbeelding 2 van 2
    • The support of the sealing is secured by a screw, mostly Tx 15.
    • On the left and right side are notches, open them and raise the support.
    • Turn it upside down.
  4. Water Tank Sealing Replacement, Replace sealing: stap 4, afbeelding 1 van 3 Water Tank Sealing Replacement, Replace sealing: stap 4, afbeelding 2 van 3 Water Tank Sealing Replacement, Replace sealing: stap 4, afbeelding 3 van 3
    • Press both plastic rivets with tiers, then push them out. The cover of the sealing is free.
    • Change sealings. The old one was black, the new one red.
    • Attach cover
Conclusie
Now follow the steps in reverse direction.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
VauWeh helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
VauWeh
165.841 Reputatie
212 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 105
Altijd: 10,028
