Ga door naar hoofdinhoud
Water Damage on main board of Nokia 206 RM873
Wat je nodig hebt
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: stap 1, afbeelding 1 van 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: stap 1, afbeelding 2 van 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: stap 1, afbeelding 3 van 3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: stap 2, afbeelding 1 van 2 Water Damage on main board of Nokia 206 RM873: stap 2, afbeelding 2 van 2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: stap 3, afbeelding 1 van 2 Water Damage on main board of Nokia 206 RM873: stap 3, afbeelding 2 van 2
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
    Nokia 206 display and charger
    Mithilesh Yadav - Antwoord
  4. Water Damage on main board of Nokia 206 RM873: stap 4, afbeelding 1 van 3 Water Damage on main board of Nokia 206 RM873: stap 4, afbeelding 2 van 3 Water Damage on main board of Nokia 206 RM873: stap 4, afbeelding 3 van 3
    • Remove keyboard by prying it open with a spudger.
    • The keyboard is secured with adhesive, be careful!
  5. Water Damage on main board of Nokia 206 RM873: stap 5, afbeelding 1 van 3 Water Damage on main board of Nokia 206 RM873: stap 5, afbeelding 2 van 3 Water Damage on main board of Nokia 206 RM873: stap 5, afbeelding 3 van 3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  6. Water Damage on main board of Nokia 206 RM873: stap 6, afbeelding 1 van 2 Water Damage on main board of Nokia 206 RM873: stap 6, afbeelding 2 van 2
    • How and where to use the cotton swabs.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Kevin D
7.276 Reputatie
21 handleidingen geschreven
4 opmerkingen
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Antwoord
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Antwoord
Nokia 206 display and charger pin
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 10,765
