Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The plastic sides can become damaged, melted or warped when using a pot larger than the burner. So be sure to remove the back panel first before pulling these sides off.
The screws are located along the interior sides of the metal frame, so consider wearing gloves when removing the screws to avoid cuts from the sharp edges.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Using a wrench, remove the bolt from the center of the back panel. Using a wrench, remove the bolt from the center of the back panel.
    • Using a wrench, remove the bolt from the center of the back panel.
  3. The back panel can now be easily lifted off.
    • The back panel can now be easily lifted off.
  4. Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame. The interior edges of the metal frame are sharp and can cause minor cuts.
    • Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
  5. Plastic sides should be easily removed after all screws are taken out.
    • Plastic sides should be easily removed after all screws are taken out.
Conclusie
Sun Fai Lau
564 Reputatie
5 handleidingen geschreven
USF Tampa, Team 10-7, Brown Fall 2014 Lid van USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 126
