Ga door naar hoofdinhoud
Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement
Wat je nodig hebt
  1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: stap 2, afbeelding 1 van 2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: stap 2, afbeelding 2 van 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: stap 3, afbeelding 1 van 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: stap 4, afbeelding 1 van 2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: stap 4, afbeelding 2 van 2
    • While using the wrench to hold the bolt, use the screwdriver to remove the screw.
    • The leg is two separate pieces, the plastic leg and rubber stopper.
    • Careful not to lose the bolts and washers as they are very small.
Conclusie
Sun Fai Lau
588 Reputatie
5 handleidingen geschreven
USF Tampa, Team 10-7, Brown Fall 2014 Lid van USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 182
