Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Using a wrench, remove the bolt from the center of the back panel.
Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
Push the screwdrivers inward and guide the bulb outwards.
Gently grab by the wires and remove bulb from plastic shell.
