Ga door naar hoofdinhoud
Waring Pro SB30 Indicator Lights Replacement
Wat je nodig hebt
  1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Indicator Lights Replacement: stap 2, afbeelding 1 van 2 Waring Pro SB30 Indicator Lights Replacement: stap 2, afbeelding 2 van 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Indicator Lights Replacement: stap 3, afbeelding 1 van 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: stap 4, afbeelding 1 van 1
    • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
  5. Waring Pro SB30 Indicator Lights Replacement: stap 5, afbeelding 1 van 2 Waring Pro SB30 Indicator Lights Replacement: stap 5, afbeelding 2 van 2
    • Push the screwdrivers inward and guide the bulb outwards.
    • Gently grab by the wires and remove bulb from plastic shell.
Conclusie
Sun Fai Lau
588 Reputatie
5 handleidingen geschreven
USF Tampa, Team 10-7, Brown Fall 2014 Lid van USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 291
