Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Using a wrench, remove the bolt from the center of the back panel.
Remove screws #1 Phillips screwdriver bit.
3 screws on the perimeter of the circle
1 screw in the circle
2 screws on the eletrical stands with wires
Remove rod from the center of the plate with a wrench.
Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
