Ga door naar hoofdinhoud
Waring Pro SB30 Hot Plate Replacement
Wat je nodig hebt
  1. Waring Pro SB30 Hot Plate Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Hot Plate Replacement: stap 2, afbeelding 1 van 2 Waring Pro SB30 Hot Plate Replacement: stap 2, afbeelding 2 van 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Hot Plate Replacement: stap 3, afbeelding 1 van 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Hot Plate Replacement, Hot Plate: stap 4, afbeelding 1 van 2 Waring Pro SB30 Hot Plate Replacement, Hot Plate: stap 4, afbeelding 2 van 2
    • Remove screws #1 Phillips screwdriver bit.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
    • 3 screws on the perimeter of the circle
    • 1 screw in the circle
    • 2 screws on the eletrical stands with wires
  5. Waring Pro SB30 Hot Plate Replacement: stap 5, afbeelding 1 van 2 Waring Pro SB30 Hot Plate Replacement: stap 5, afbeelding 2 van 2
    • Remove rod from the center of the plate with a wrench.
  6. Waring Pro SB30 Hot Plate Replacement: stap 6, afbeelding 1 van 2 Waring Pro SB30 Hot Plate Replacement: stap 6, afbeelding 2 van 2
    • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
Conclusie
Sun Fai Lau
588 Reputatie
5 handleidingen geschreven
USF Tampa, Team 10-7, Brown Fall 2014 Lid van USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,927
