Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The back panel located on the underside of the burner and is held in place by multiple screws. Take care when removing the screws as it may require a good amount of force if the panel has never been removed.
Wat je nodig hebt
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Één andere persoon heeft deze handleiding voltooid.
