Ga door naar hoofdinhoud
Waring 51BL29 Switch Replacement
Wat je nodig hebt
  1. Waring 51BL29 Switch Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Waring 51BL29 Switch Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom panel.
  3. Waring 51BL29 Switch Replacement, Drive Coupling: stap 3, afbeelding 1 van 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Switch Replacement: stap 4, afbeelding 1 van 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Switch Replacement: stap 5, afbeelding 1 van 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Switch Replacement, Motor: stap 6, afbeelding 1 van 2 Waring 51BL29 Switch Replacement, Motor: stap 6, afbeelding 2 van 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Switch Replacement: stap 7, afbeelding 1 van 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Switch Replacement: stap 8, afbeelding 1 van 3 Waring 51BL29 Switch Replacement: stap 8, afbeelding 2 van 3 Waring 51BL29 Switch Replacement: stap 8, afbeelding 3 van 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Switch Replacement, Switch: stap 9, afbeelding 1 van 1
    • Once you have the motor and switch by themselves it should look like this.
  10. Waring 51BL29 Switch Replacement: stap 10, afbeelding 1 van 2 Waring 51BL29 Switch Replacement: stap 10, afbeelding 2 van 2
    • Separate the zip-tie holding the wires to the motor.
  11. Waring 51BL29 Switch Replacement: stap 11, afbeelding 1 van 1
    • Now the switch is separated from the motor and blender frame.
Conclusie
Dean Becker
470 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G4, Banghart Spring 2017 Lid van Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 686
