Inleiding
The motor is the main component of the blender underneath the bottom plate. This guide will walk you through how to remove it step-by-step.
Wat je nodig hebt
Turn the blender on its side so the bottom panel is facing you.
Unscrew the 22mm Phillips #1 screw on the indent of the panel.
Unscrew the 3 screws in the rubber holes.
Unscrew the four nuts in the bottom of the motor cavity.
Wiggle the motor until it is free and you can remove it.
Één opmerking
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
