Inleiding
The drive coupling is the small gear-like piece attached to the top of the blender base where it serves to attach the motor to the blades. If the teeth are worn down it should be replaced by following these steps.
Wat je nodig hebt
Turn the blender on its side so the bottom panel is facing you.
Unscrew the 22mm Phillips #1 screw on the indent of the panel.
Unscrew the 3 screws in the rubber holes.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Do you happen to know where I can purchase this replacement part?
