Ga door naar hoofdinhoud
Wall Outlet Cover Replacement
Wat je nodig hebt
  1. Wall Outlet Cover Replacement, Wall Outlet Cover: stap 1, afbeelding 1 van 3 Wall Outlet Cover Replacement, Wall Outlet Cover: stap 1, afbeelding 2 van 3 Wall Outlet Cover Replacement, Wall Outlet Cover: stap 1, afbeelding 3 van 3
    • Remove any hazardous pieces from previous cover.
    • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
  2. Wall Outlet Cover Replacement: stap 2, afbeelding 1 van 3 Wall Outlet Cover Replacement: stap 2, afbeelding 2 van 3 Wall Outlet Cover Replacement: stap 2, afbeelding 3 van 3
    • Insert any cable or cables that may be hanging out inside of the wall hole.
    • Making a loop in the cable might be helpful to push it inside the wall.
  3. Wall Outlet Cover Replacement: stap 3, afbeelding 1 van 1
    • Insert two screws into the holes of the new wall cover.
  4. Wall Outlet Cover Replacement: stap 4, afbeelding 1 van 3 Wall Outlet Cover Replacement: stap 4, afbeelding 2 van 3 Wall Outlet Cover Replacement: stap 4, afbeelding 3 van 3
    • Line up the screws in the plate with the screw holes in the wall.
    • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
    • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
  5. Wall Outlet Cover Replacement: stap 5, afbeelding 1 van 3 Wall Outlet Cover Replacement: stap 5, afbeelding 2 van 3 Wall Outlet Cover Replacement: stap 5, afbeelding 3 van 3
    • Tighten the two screws with a flathead screwdriver.
  6. Wall Outlet Cover Replacement: stap 6, afbeelding 1 van 3 Wall Outlet Cover Replacement: stap 6, afbeelding 2 van 3 Wall Outlet Cover Replacement: stap 6, afbeelding 3 van 3
    • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
    • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
Conclusie
Leydi Navarrete
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 62
Altijd: 1,098
