Inleiding
Use this guide to replace the power switch on your device.
Wat je nodig hebt
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Één opmerking
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
