Ga door naar hoofdinhoud
Wahl Chrome Pro Power Cord Replacement
Wat je nodig hebt
  1. Wahl Chrome Pro Power Cord Replacement, Case: stap 1, afbeelding 1 van 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Power Cord Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Power Cord Replacement: stap 6, afbeelding 1 van 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Power Cord Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Power Cord Replacement: stap 8, afbeelding 1 van 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Power Cord Replacement, Power Cord: stap 9, afbeelding 1 van 2 Wahl Chrome Pro Power Cord Replacement, Power Cord: stap 9, afbeelding 2 van 2
    • Remove one 7.5 mm JIS #1 screw from the switch base.
  10. Wahl Chrome Pro Power Cord Replacement: stap 10, afbeelding 1 van 1
    • Unplug the cord terminal from the motor connector.
  11. Wahl Chrome Pro Power Cord Replacement: stap 11, afbeelding 1 van 1
    • Remove the cord from the device base by pulling gently.
Conclusie
Manuel Salazar M.
101 Reputatie
1 Handleiding geschreven
IUPUI, Team S7-G3, Baechle Fall 2017 Lid van IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 806
