Ga door naar hoofdinhoud
Wacom Intuos4 Motherboard Replacement
Wat je nodig hebt
  1. Wacom Intuos4 Motherboard Replacement, Casing: stap 1, afbeelding 1 van 3 Wacom Intuos4 Motherboard Replacement, Casing: stap 1, afbeelding 2 van 3 Wacom Intuos4 Motherboard Replacement, Casing: stap 1, afbeelding 3 van 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Motherboard Replacement: stap 2, afbeelding 1 van 2 Wacom Intuos4 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 2 Wacom Intuos4 Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Motherboard Replacement: stap 4, afbeelding 1 van 2 Wacom Intuos4 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Motherboard Replacement: stap 5, afbeelding 1 van 2 Wacom Intuos4 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
Conclusie
Jack Palmgren
231 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 94
