Ga door naar hoofdinhoud
Wacom Intuos4 Express Keys Replacement
Wat je nodig hebt
  1. Wacom Intuos4 Express Keys Replacement, Casing: stap 1, afbeelding 1 van 3 Wacom Intuos4 Express Keys Replacement, Casing: stap 1, afbeelding 2 van 3 Wacom Intuos4 Express Keys Replacement, Casing: stap 1, afbeelding 3 van 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Express Keys Replacement: stap 2, afbeelding 1 van 2 Wacom Intuos4 Express Keys Replacement: stap 2, afbeelding 2 van 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Express Keys Replacement, Express Keys: stap 3, afbeelding 1 van 3 Wacom Intuos4 Express Keys Replacement, Express Keys: stap 3, afbeelding 2 van 3 Wacom Intuos4 Express Keys Replacement, Express Keys: stap 3, afbeelding 3 van 3
    • Lift yellow tape covering the flat wires with a pair of tweezers.
    • Lift the black plastic clip holding the flat wire to the connector.
    • This should be done with a plastic tool to avoid damaging the contacts.
    • Pull on the white plastic tab to disconnect the flat wire.
    • Do this for the left and right express key chips.
  4. Wacom Intuos4 Express Keys Replacement: stap 4, afbeelding 1 van 1
    • Pull the black plastic clip away from the flat wire connector, and pull the flat wire out.
    • It may be easier to pull with a tool on one side, and with your hand on the other at the same time.
  5. Wacom Intuos4 Express Keys Replacement: stap 5, afbeelding 1 van 1
    • Use a #1 Phillips head screwdriver to unscrew the four 5mm screws on the express key board you want to replace.
  6. Wacom Intuos4 Express Keys Replacement: stap 6, afbeelding 1 van 2 Wacom Intuos4 Express Keys Replacement: stap 6, afbeelding 2 van 2
    • Lift the board and rubber buttons up from the case.
    • Separate the rubber buttons from the board.
Conclusie
Aidan Sullivan
281 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 83
