Inleiding
This guide includes clear steps on how to properly remove and replace a motherboard in a Wacom Intuos Pro tablet. If you run into a situation where a certain part of your touchpad doesn’t work, then this is the guide for you. You will need a Phillips #00 screwdriver, and soldering kit. Be very careful when using a soldering iron. The element can reach up to 400 degrees celsius! Remember to keep the sponge wet at all times. Lastly, remember to return the iron to its stand when not in use.
Wat je nodig hebt
Orient the device so the bottom casing is facing upwards.
Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
Één andere persoon heeft deze handleiding voltooid.
