Ga door naar hoofdinhoud
Wacom Intuos CTL4100 Battery Replacement
Wat je nodig hebt
  1. Wacom Intuos CTL4100 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Wacom Intuos CTL4100 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Wacom Intuos CTL4100 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the tablet over so the bottom case faces upwards.
    • Remove the rubber pads on the corners by pulling them up with your fingers.
  2. Wacom Intuos CTL4100 Battery Replacement: stap 2, afbeelding 1 van 3 Wacom Intuos CTL4100 Battery Replacement: stap 2, afbeelding 2 van 3 Wacom Intuos CTL4100 Battery Replacement: stap 2, afbeelding 3 van 3
  3. Wacom Intuos CTL4100 Battery Replacement: stap 3, afbeelding 1 van 3 Wacom Intuos CTL4100 Battery Replacement: stap 3, afbeelding 2 van 3 Wacom Intuos CTL4100 Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
    • Slide your plastic opening pick around the sides until all clips are unclipped.
  4. Wacom Intuos CTL4100 Battery Replacement: stap 4, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 4, afbeelding 2 van 2
    • Lift the bottom case to separate the top and bottom case
    • When you see the internal components, set aside the bottom case.
  5. Wacom Intuos CTL4100 Battery Replacement: stap 5, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the yellow tape that is on top of the battery wires.
    • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
  6. Wacom Intuos CTL4100 Battery Replacement: stap 6, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 6, afbeelding 2 van 2
    • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
  7. Wacom Intuos CTL4100 Battery Replacement: stap 7, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the battery by lifting the battery up with your fingers.
  8. Wacom Intuos CTL4100 Battery Replacement: stap 8, afbeelding 1 van 1
    • Place the new battery on the area you removed the battery.
  9. Wacom Intuos CTL4100 Battery Replacement: stap 9, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 9, afbeelding 2 van 2
    • Gently connect the battery wire pin to the motherboard.
  10. Wacom Intuos CTL4100 Battery Replacement: stap 10, afbeelding 1 van 2 Wacom Intuos CTL4100 Battery Replacement: stap 10, afbeelding 2 van 2
    • Reapply the tape you put above the battery wires.
Conclusie
To reassemble your device, follow step 4 in reverse order.
5 andere personen hebben deze handleiding voltooid.
Marcus Sisouphanh
316 Reputatie
1 Handleiding geschreven
York University, Team 1-24, O'Regan Fall 2021 Lid van York University, Team 1-24, O'Regan Fall 2021
YORK-O'REGAN-F21S1G24
1 Lid
2 handleidingen geschreven
5Gids Commentaar
Where did you get the replacement battery?
David VeLar - Antwoord
Will it work without a battery?
Jordi Prats - Antwoord
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Jordi Prats -
Where did you get the battery pls?
Taaa - Antwoord
I can probably say Aliexpress would be your best bet.
Gabriel Smirnov -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 154
Altijd: 4,699
