Inleiding
Wacom Cintiq Pro 13 is a tricky device to disassemble.
- Main screws holding the casing to the display are hidden under rubber feet held by strong adhesive.
- Most screws however, are common #0 Phillips type and come into two sizes, easy to distinguish between casing screws and mainboard screws.
- Replacement components are not easily available and the easiest way to get them is to buy a broken unit and swap parts as needed.
Before you begin, there are not a lot of user serviceable parts inside - take a look on the “Internal Components” list on the main page of the device to see what can be replaced without soldering and mainboard component level servicing knowledge.
Wat je nodig hebt
Heat up the bottom rubber plate near holes using heat gun or hairdryer and try to insert prying tool as adhesive softens.
As the adhesive softens, try to insert flat plastic tool on the top
Heat up the rest of the rubber plate and slide plastic tool along upper side of the rubber plate
Remove the rubber plate
The bottom part of the device will come loose allowing you to place finger between the case and the display assembly
Unclip hidden clips on left or right side and continue to opposite side. Plastic flat tool may come in handy here
Unclip all twelve clips. Keep one hand on the display to decrease display bending and second to slowly lift the back cover.
Remove the back cover
Release the latch of the audio jack flex cable port on the mainboard
Release the latch of the control board flex cable
Repeat the procedure for the flex cable connector on the mainboard
Remove the cable
Remove the adhesive from the mainboard
Slide the cable towards the mainboard by holding it as near the connector as possible
If cable seems hard to remove, try to push one side of the connector using a pair of tweezers by spots marked on third image
Repeat the steps for another end of the cable connected to the mainboard
Remove the display connector
Press on the latch on left or right side of the cable
Slide one part of the cable just a bit
Repeat steps for the other side of the cable
Slide out the cable
Remove the mainboard by sliding it forward and then lift it up
To reassemble your device, follow these instructions in reverse order. It is recommended to replace adhesive under rubber feet and the bottom rubber pad.
2 opmerkingen
Thanks for this guide - it’s great!! I have a Wacom Mobile Studio Pro 13, and have just managed to order a new battery - would the guide above be enough to follow to access and remove the battery? Or do you think there may be some additional steps? Im not familiar with the Cintiq pro, but assume theyre reasonably similar…
Thank you for the Guide. The Cintiqe Pro 16 is of the same build and the open up part of the guide also works for that.
Differences:
Step 5: There are 7 Screws under the rubber
Step 9: The full cover has the two fans embedded into it, which are connected with 2 cables to the baseboard. You can simply unblug those to get the cover off.
