Inleiding
Wear and tear can damage or jam the buttons on the Cintiq 24HD over time. Without the buttons you can not properly use the Cintiq 24HD. This guide will walk you through replacing the power button.
Wat je nodig hebt
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Één andere persoon heeft deze handleiding voltooid.
