Ga door naar hoofdinhoud
Wacom Cintiq 24HD Display Control Buttons Replacement
Wat je nodig hebt
  1. Wacom Cintiq 24HD Display Control Buttons Replacement, Stand: stap 1, afbeelding 1 van 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Display Control Buttons Replacement: stap 2, afbeelding 1 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement: stap 2, afbeelding 2 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement: stap 2, afbeelding 3 van 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Display Control Buttons Replacement: stap 3, afbeelding 1 van 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: stap 4, afbeelding 1 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: stap 4, afbeelding 2 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: stap 4, afbeelding 3 van 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD Display Control Buttons Replacement: stap 5, afbeelding 1 van 2 Wacom Cintiq 24HD Display Control Buttons Replacement: stap 5, afbeelding 2 van 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: stap 6, afbeelding 1 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: stap 6, afbeelding 2 van 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: stap 6, afbeelding 3 van 3
    • Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
    • Remove metal holding plate by lifting up and off of the button board.
  7. Wacom Cintiq 24HD Display Control Buttons Replacement: stap 7, afbeelding 1 van 1
    • Remove the button board by pinching the wiring close to the connector and gently pulling straight out from the port.
  8. Wacom Cintiq 24HD Display Control Buttons Replacement: stap 8, afbeelding 1 van 1
    • Remove the button cover by pushing the buttons out of their holes and pulling the cover up.
Conclusie
Jay Sung
481 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G3, White Fall 2018 Lid van Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 1,506
