Inleiding
Use this guide to remove or replace the bellows on a Wacker BS50-4AS REV 101 (2019) Vibrator/Rammer.
This model requires up to 0.7 liters of SAE 10W-40 oil to replace drained oil.
Wat je nodig hebt
Firmly grip the base of the spark plug wire's connector and pull it away from the spark plug to disconnect it.
Use a 1-1/16 inch socket to break loose the oil sight gauge near the bottom of the device.
Lay the device down horizontally with the oil sight gauge facing down.
Position a shallow oil drain pan underneath the sight gauge.
Remove the oil sight gauge.
Let the oil drain until drips are infrequent.
Replace and retighten the oil sight gauge.
Flip the device onto the work surface such that the motor and handles face up.
Place two separate blocks of wood underneath the seam between the leg assembly and crankcase.
Use an 8 mm hex key socket to remove the four bolts securing the leg's guiding cylinder to the crankcase.
Pull the leg assembly away from the rest of the device.
Continue to separate the two halves by compressing the bellows until the nylon plug covering the piston pin is visible.
Use an appropriately-sized punch and a ball-peen hammer to tap the pin out of its hole on the guide piston until it is no longer securing the connecting rod.
Use a punch and hammer to tap the pin out of the guide piston.
Use a 13 mm socket or large flathead screwdriver to loosen the two hose clamp bolts securing the bellows to the leg assembly.
Use a rubber mallet to tap the bellows down and off of the top of the guide cylinder.
Once loose, pull the bellows off of the lip on the guide cylinder.
Use a rubber mallet to tap the bellows up and off of the top of the protective pipe.
Once loose, pull the bellows off of the lip on the protective pipe.
Remove the bellows.
After reassembly, tilt the device upright and check the oil level through the sight glass. The oil should cover 1/2 to 3/4 of the sight glass to be considered full. This model requires up to 0.7 liters of SAE 10W-40 oil.
Één andere persoon heeft deze handleiding voltooid.
