Inleiding
Replacing the Intel Centrino Wireless Chipset with a component that meets the same standard.
Wat je nodig hebt
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
Here is the WLAN Chipset / Bluetooth
Gently unplug the MAIN and AUX antennas.
Unscrew the fixing screw with Philips # 0 screwdriver.
To reassemble your device follow the following instructions in reverse order
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
