Inleiding
Use this guide to replace a faulty motherboard on your Vulcan Venture II (VNB14002IE) laptop. Your laptop may have a faulty motherboard if you experience frequent crashes, shutdowns, reboots or no power. Ensure your laptop is fully powered down before removing any part. If you're unsure that it's fully powered down, open and power the laptop and shut it down from the start menu.
Wat je nodig hebt
Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
Disconnect the wire connected to the motherboard.
Disconnect the battery by gently pulling out the cable connected to the board.
