Ga door naar hoofdinhoud
Vulcan Venture II VNB14002IE Motherboard Replacement
Wat je nodig hebt
  1. Vulcan Venture II VNB14002IE Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
    • Disconnect the wire connected to the motherboard.
    • Disconnect the battery by gently pulling out the cable connected to the board.
  4. Vulcan Venture II VNB14002IE Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the screws located in the corners of the board using a J00 screwdriver.
  5. Vulcan Venture II VNB14002IE Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the board out of the housing without any cables still connected to the board.
    • Picture shows the housing of the motherboard after the motherboard has been removed.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 424
