Ga door naar hoofdinhoud
VuPoint DC-ST210-VP Shutter Button Replacement
Wat je nodig hebt
  1. VuPoint DC-ST210-VP Shutter Button Replacement, Turn Off/Remove Batteries: stap 1, afbeelding 1 van 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: stap 2, afbeelding 1 van 3 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: stap 2, afbeelding 2 van 3 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: stap 2, afbeelding 3 van 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: stap 3, afbeelding 1 van 2 VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: stap 3, afbeelding 2 van 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: stap 4, afbeelding 1 van 2 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: stap 4, afbeelding 2 van 2
    • With the back plate off, use a screw driver to remove the 6 screws shown to the left.
    • Gently separate the circuit board from frame, by prying the circuit board from base.
  5. VuPoint DC-ST210-VP Shutter Button Replacement, Move Plastic Protector: stap 5, afbeelding 1 van 1
    • Using your finger rotate the dark grey piece away from the shutter button.
  6. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: stap 6, afbeelding 1 van 2 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: stap 6, afbeelding 2 van 2
    • Remove the shutter button by gently pressing the button from the top, pushing it towards the inside of the camera. Press shutter button down and wiggle slightly until the shutter button comes loose from housing.
    • Replace as necessary.
Conclusie
Lincoln Thompson
32 Reputatie
2 handleidingen geschreven
Baylor, Team 8-15, Williams Fall 2014 Lid van Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 472
