Ga door naar hoofdinhoud
VuPoint DC-ST210-VP LCD Screen Replacement
Wat je nodig hebt
  1. VuPoint DC-ST210-VP LCD Screen Replacement, Turn Off/Remove Batteries: stap 1, afbeelding 1 van 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: stap 2, afbeelding 1 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: stap 2, afbeelding 2 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: stap 2, afbeelding 3 van 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: stap 3, afbeelding 1 van 2 VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: stap 3, afbeelding 2 van 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Circuit Board Screws: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
    • Remember to place small screws on magnetic mat or in a container.
  5. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: stap 5, afbeelding 1 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: stap 5, afbeelding 2 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: stap 5, afbeelding 3 van 3
    • Using a pry tool or fingernail, gently pry the circuit board from the base.
    • Gently lift the lower right hand corner of the circuit board, separating it from the base.
  6. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: stap 6, afbeelding 1 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: stap 6, afbeelding 2 van 3 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: stap 6, afbeelding 3 van 3
    • Locate LCD and gently bend it back to reveal ribbon cable connector.
    • Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
    • Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
    • Replace LCD as needed and repeat steps in reverse to reassemble.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lincoln Thompson
32 Reputatie
2 handleidingen geschreven
Baylor, Team 8-15, Williams Fall 2014 Lid van Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 607
