Ga door naar hoofdinhoud
VuPoint DC-ST210-VP Battery Door Cover Replacement
Wat je nodig hebt
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: stap 1, afbeelding 1 van 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: stap 2, afbeelding 1 van 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: stap 2, afbeelding 2 van 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: stap 2, afbeelding 3 van 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: stap 3, afbeelding 1 van 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: stap 3, afbeelding 2 van 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: stap 4, afbeelding 1 van 1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: stap 5, afbeelding 1 van 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: stap 5, afbeelding 2 van 2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: stap 6, afbeelding 1 van 1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
Conclusie
Elise Brown
70 Reputatie
2 handleidingen geschreven
Baylor, Team 8-15, Williams Fall 2014 Lid van Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 356
