Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise. Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. When reassembling, align the notch on the battery panel with the slot on the phone. When reassembling, align the notch on the battery panel with the slot on the phone. When reassembling, align the notch on the battery panel with the slot on the phone.
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver. Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Lift directly up to remove the switch and lay the wire down to the side. Once the switch has been taken out you can remove the switch's casing. Once the switch has been taken out you can remove the switch's casing.
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
tellocordova
342 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-4, Sullivan Fall 2015 Lid van USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Leden
6 handleidingen geschreven
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Antwoord
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 440
