Inleiding
A faulty volume switch can often lead to distorted audio or even no audio at all. This guide is designed to show how to correctly replace the volume switch for your drum set in order to restore sound and proper function.
Wat je nodig hebt
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
Loosen and remove the two 8 mm screws using a Phillips #00 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
