Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
A broken or cracked cymbal can be very hazardous to small children. Additionally, a damaged cymbal could prevent the drum set from working properly. This guide is designed to show how to correctly replace the green cymbal in order restore your drum set to a safe and functioning condition.
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Using your fingers, pry open and remove the back battery panel.
    • Using your fingers, pry open and remove the back battery panel.
  4. Use your fingers to remove each battery from its housing.
    • Use your fingers to remove each battery from its housing.
  5. Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  7. With your hands, separate the bottom panel from the drum set. When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  8. Use Phillips #2 screwdriver to loosen and remove the single 16 mm screw.
    • Use Phillips #2 screwdriver to loosen and remove the single 16 mm screw.
  9. Using your hands, remove the blue cymbal stand from the orange base.
    • Using your hands, remove the blue cymbal stand from the orange base.
  10. Loosen and remove the two 14 mm screws using a Phillips #2 screwdriver.
    • Loosen and remove the two 14 mm screws using a Phillips #2 screwdriver.
  11. Using your hands, separate the two halves of the blue cymbal stand.
    • Using your hands, separate the two halves of the blue cymbal stand.
  12. Using your hands, separate the green cymbal from the blue cymbal base.
    • Using your hands, separate the green cymbal from the blue cymbal base.
  13. Using a Phillips #00 screwdriver, loosen and remove the three 12 mm screws located on the bottom of the green cymbal.
    • Using a Phillips #00 screwdriver, loosen and remove the three 12 mm screws located on the bottom of the green cymbal.
  14. Using your hands, separate the green cymbal from the green cymbal base.
    • Using your hands, separate the green cymbal from the green cymbal base.
  15. Using your hands, pull apart the green cymbal from the yellow light casing.
    • Using your hands, pull apart the green cymbal from the yellow light casing.
Conclusie
Aaron Klementowski
763 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-8, Cagle Spring 2016 Lid van USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 228
