Ga door naar hoofdinhoud
Vornado 133 Compact Air Circulator Fuse Replacement
Wat je nodig hebt
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: stap 1, afbeelding 1 van 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 1 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 2 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 2, afbeelding 3 van 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 1 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 2 van 3 Vornado 133 Compact Air Circulator Fuse Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Conclusie
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 andere personen hebben deze handleiding voltooid.
Erin Klein
483 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G2, Liner Summer 2017 Lid van UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Leden
4 handleidingen geschreven
10 opmerkingen
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Antwoord
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Antwoord
Fast-acting or slow-acting?
James Olsen - Antwoord
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Antwoord
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 86
Altijd: 33,708
