Ga door naar hoofdinhoud
Voluas VL001 Silicone Hopper Feeder Replacement
Wat je nodig hebt
  1. Voluas VL001 Silicone Hopper Feeder Replacement, Storage Tank: stap 1, afbeelding 1 van 3 Voluas VL001 Silicone Hopper Feeder Replacement, Storage Tank: stap 1, afbeelding 2 van 3 Voluas VL001 Silicone Hopper Feeder Replacement, Storage Tank: stap 1, afbeelding 3 van 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Silicone Hopper Feeder Replacement, Silicone Hopper Feeder: stap 2, afbeelding 1 van 3 Voluas VL001 Silicone Hopper Feeder Replacement, Silicone Hopper Feeder: stap 2, afbeelding 2 van 3 Voluas VL001 Silicone Hopper Feeder Replacement, Silicone Hopper Feeder: stap 2, afbeelding 3 van 3
    • Grab the spindle from the bottom.
    • This will prevent the feeder from spinning while you loosen the screw.
    • Using a Phillips #2 screwdriver, remove the single 11.6 mm screw in the center of the topside of the feeder mechanism.
    • Once the screw is removed, grab the three-pronged silicone agitator and remove it from the feeder.
  3. Voluas VL001 Silicone Hopper Feeder Replacement: stap 3, afbeelding 1 van 3 Voluas VL001 Silicone Hopper Feeder Replacement: stap 3, afbeelding 2 van 3 Voluas VL001 Silicone Hopper Feeder Replacement: stap 3, afbeelding 3 van 3
    • Flip the storage tank over so that the bottom side is facing up.
    • Using a Phillips #2 screwdriver, remove the three 11.3 mm screws that hold the plastic cap onto the bottom of the tank.
    • Lift the plastic cap off the tank.
  4. Voluas VL001 Silicone Hopper Feeder Replacement: stap 4, afbeelding 1 van 2 Voluas VL001 Silicone Hopper Feeder Replacement: stap 4, afbeelding 2 van 2
    • Firmly grab the spindle of the mechanism and remove it from the bottom of the tank.
Conclusie
Jade Thomson
699 Reputatie
6 handleidingen geschreven
Één opmerking
Do you know where to get a replacement part? They say they don’t sell them.
Abigail Donnolly - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 96
