Inleiding
If your Voluas VL001 pet feeder is having problems with getting food out, you may have an issue with your feeder mechanism. This is the part that has a fan-like shape and rotates to dispense food out of the device.
Wat je nodig hebt
Remove the lid to the storage tank by using the latch and lifting off.
Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
Grab the spindle from the bottom.
Using a Phillips #2 screwdriver, remove the single 11.6 mm screw in the center of the topside of the feeder mechanism.
Once the screw is removed, grab the three-pronged silicone agitator and remove it from the feeder.
Één opmerking
Do you know where to get a replacement part? They say they don’t sell them.
