Ga door naar hoofdinhoud
Voluas VL001 Motor Assembly Gears Replacement
Wat je nodig hebt
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: stap 1, afbeelding 1 van 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: stap 1, afbeelding 2 van 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: stap 1, afbeelding 3 van 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: stap 2, afbeelding 1 van 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: stap 2, afbeelding 2 van 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: stap 2, afbeelding 3 van 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: stap 3, afbeelding 1 van 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: stap 3, afbeelding 2 van 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: stap 3, afbeelding 3 van 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Motor Assembly Gears Replacement: stap 4, afbeelding 1 van 2 Voluas VL001 Motor Assembly Gears Replacement: stap 4, afbeelding 2 van 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Motor Assembly Gears Replacement: stap 5, afbeelding 1 van 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: stap 6, afbeelding 1 van 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: stap 6, afbeelding 2 van 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: stap 6, afbeelding 3 van 3
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
  7. Voluas VL001 Motor Assembly Gears Replacement: stap 7, afbeelding 1 van 1
    • Lift the electric motor from its housing and move it aside.
  8. Voluas VL001 Motor Assembly Gears Replacement: stap 8, afbeelding 1 van 2 Voluas VL001 Motor Assembly Gears Replacement: stap 8, afbeelding 2 van 2
    • Use the tweezers to remove the first gear that is placed on top.
  9. Voluas VL001 Motor Assembly Gears Replacement: stap 9, afbeelding 1 van 2 Voluas VL001 Motor Assembly Gears Replacement: stap 9, afbeelding 2 van 2
    • Use the tweezers to gently remove the second gear.
  10. Voluas VL001 Motor Assembly Gears Replacement: stap 10, afbeelding 1 van 2 Voluas VL001 Motor Assembly Gears Replacement: stap 10, afbeelding 2 van 2
    • Use the tweezers to gently remove the third gear.
Conclusie
Jade Thomson
699 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 32
