Ga door naar hoofdinhoud
Vizio VTAB1008 Front Facing Camera Replacement
Wat je nodig hebt
  1. Vizio VTAB1008 Front Facing Camera Replacement, Vizio VTAB1008 Back Cover Removal: stap 1, afbeelding 1 van 2 Vizio VTAB1008 Front Facing Camera Replacement, Vizio VTAB1008 Back Cover Removal: stap 1, afbeelding 2 van 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Front Facing Camera Replacement, Front Facing Camera and Light Sensor Board: stap 3, afbeelding 1 van 2 Vizio VTAB1008 Front Facing Camera Replacement, Front Facing Camera and Light Sensor Board: stap 3, afbeelding 2 van 2
    • Remove the screw with the J1 screwdriver or screw bit.
    • The screw has a 3.66 mm head and is 3.5 mm tall.
  4. Vizio VTAB1008 Front Facing Camera Replacement: stap 4, afbeelding 1 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 4, afbeelding 2 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Lift the flap hiding the second screw.
    • Remove the screw by using the J1 screwdriver.
  5. Vizio VTAB1008 Front Facing Camera Replacement: stap 5, afbeelding 1 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 5, afbeelding 2 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the black and red cable connector from the camera strap.
    • Using tweezers may help to grab the small connector flanges.
  6. Vizio VTAB1008 Front Facing Camera Replacement: stap 6, afbeelding 1 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 6, afbeelding 2 van 3 Vizio VTAB1008 Front Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the ribbon cable from the camera circuit board by lifting it away from the circuit board.
    • A spudger may help with leverage when removing the ribbon cable.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 136
