Ga door naar hoofdinhoud
Vizio CT15 Keyboard Replacement
Wat je nodig hebt
  1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: stap 1, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: stap 1, afbeelding 2 van 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Keyboard Replacement, Battery: stap 2, afbeelding 1 van 1
  3. Vizio CT15 Keyboard Replacement: stap 3, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Keyboard Replacement, Speakers: stap 4, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement, Speakers: stap 4, afbeelding 2 van 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Keyboard Replacement: stap 5, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Keyboard Replacement: stap 6, afbeelding 1 van 3 Vizio CT15 Keyboard Replacement: stap 6, afbeelding 2 van 3 Vizio CT15 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Keyboard Replacement: stap 7, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  8. Vizio CT15 Keyboard Replacement, CPU Fan: stap 8, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement, CPU Fan: stap 8, afbeelding 2 van 2
    • Unplug the fan from the motherboard.
  9. Vizio CT15 Keyboard Replacement: stap 9, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  10. Vizio CT15 Keyboard Replacement, Keyboard: stap 10, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement, Keyboard: stap 10, afbeelding 2 van 2
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  11. Vizio CT15 Keyboard Replacement: stap 11, afbeelding 1 van 2 Vizio CT15 Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  12. Vizio CT15 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  13. Vizio CT15 Keyboard Replacement: stap 13, afbeelding 1 van 3 Vizio CT15 Keyboard Replacement: stap 13, afbeelding 2 van 3 Vizio CT15 Keyboard Replacement: stap 13, afbeelding 3 van 3
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
jalon
115 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 854
