Ga door naar hoofdinhoud
Vivitar DVR 781HD Front Case Replacement
Wat je nodig hebt
  1. Vivitar DVR 781HD Front Case Replacement, Front Case: stap 1, afbeelding 1 van 3 Vivitar DVR 781HD Front Case Replacement, Front Case: stap 1, afbeelding 2 van 3 Vivitar DVR 781HD Front Case Replacement, Front Case: stap 1, afbeelding 3 van 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Front Case Replacement: stap 2, afbeelding 1 van 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Front Case Replacement: stap 3, afbeelding 1 van 3 Vivitar DVR 781HD Front Case Replacement: stap 3, afbeelding 2 van 3 Vivitar DVR 781HD Front Case Replacement: stap 3, afbeelding 3 van 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
Conclusie
Jordan Baum
355 Reputatie
2 handleidingen geschreven
IUPUI, Team 54-6, Wilson Spring 2016 Lid van IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 308
