Ga door naar hoofdinhoud
Visual Land Prestige 7L Front Facing Camera Replacement
Wat je nodig hebt
  1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: stap 1, afbeelding 1 van 2 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Front Facing Camera Replacement: stap 2, afbeelding 1 van 3 Visual Land Prestige 7L Front Facing Camera Replacement: stap 2, afbeelding 2 van 3 Visual Land Prestige 7L Front Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Front Facing Camera Replacement: stap 3, afbeelding 1 van 3 Visual Land Prestige 7L Front Facing Camera Replacement: stap 3, afbeelding 2 van 3 Visual Land Prestige 7L Front Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 1 van 2 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 2 van 2
    • Remove the adhesive padding.
  5. Visual Land Prestige 7L Front Facing Camera Replacement: stap 5, afbeelding 1 van 2 Visual Land Prestige 7L Front Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Unclip the connector that attaches the camera to the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
    • Gently pop the camera out of the connector and off the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Greg Azzalina
263 Reputatie
1 Handleiding geschreven
Penn State, Team 2-25, Kaschak Winter 2015 Lid van Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 280
