Inleiding
This guide is useful for replacing the rear case, but it's also the first steps necessary to take apart the device if you want to replace any other components inside. If you're looking to fix any hardware-based problems on your device, start here.
Wat je nodig hebt
Remove the two 8mm Phillips Head screws located at the bottom of your device.
Één andere persoon heeft deze handleiding voltooid.
