Ga door naar hoofdinhoud
Vintage Plug Replacement
Wat je nodig hebt
  1. Vintage Plug Replacement, Plug: stap 1, afbeelding 1 van 2 Vintage Plug Replacement, Plug: stap 1, afbeelding 2 van 2
    • Place your plug on a flat surface.
    • Place the standard cutting plieres about an inch below the end of the plug.
    • Tightly cut down on the wire until the plug is completely removed from the wire, as seen in Photo 2.
  2. Vintage Plug Replacement: stap 2, afbeelding 1 van 3 Vintage Plug Replacement: stap 2, afbeelding 2 van 3 Vintage Plug Replacement: stap 2, afbeelding 3 van 3
    • Always be careful with knives. Never point them at yourself while cutting and always fold them when finished.
    • Comparing the length of your new plug, take your cutting knife, and mark a line where the end of the plug lines up with the wire.
    • The recommended length to cut in order to properly strip the wire is about an inch and a half, and can be measured using the plug.
  3. Vintage Plug Replacement: stap 3, afbeelding 1 van 2 Vintage Plug Replacement: stap 3, afbeelding 2 van 2
    • Remove the two screws on the top of the colored panel where the plugs exit and set them aside with your plug.
    • Don't lose the two screws you just set aside! Make sure they are far away from any corners or holes where they could fall into.
  4. Vintage Plug Replacement: stap 4, afbeelding 1 van 3 Vintage Plug Replacement: stap 4, afbeelding 2 van 3 Vintage Plug Replacement: stap 4, afbeelding 3 van 3
    • With the casing now cut open, peel it back until the inner two wires are fully exposed like in Photo 2.
    • Cut off the excess casing you have peeled back; it's not necessary anymore and will only prevent you from feeding the wire into the plug.
    • Take your wire and tighten it with your pliers if necessary, then feed it through the bottom hole of the plug. Pull down until you have enough room to move the wire around.
  5. Vintage Plug Replacement: stap 5, afbeelding 1 van 2 Vintage Plug Replacement: stap 5, afbeelding 2 van 2
    • You may notice the casing on the end of the wires here look a lot different. This is because wires from the 70's and prior were insulted using cloth or fabric. This may make them a little more annoying to strip, so keep in mind you may need more force.
    • Take your standard wire stripper, and using the size gauge, take your wire and put it roughly about an inch into the hole, about the length of your fingernail.
    • Clamp down onto the insulation, and twist the wire before pulling upwards towards the end of the wire. The insulation will fray and eventually cut off. Your end result should resemble Picture 2.
    • Fabric insulation can be a little trickier to remove, even after stripped. You can used your knife to very carefully cut off the ends that remain attached without any damage to the wire, but be careful as this is a bit closer to your hand.
  6. Vintage Plug Replacement: stap 6, afbeelding 1 van 1
    • Loosen the holding screws from the detached colored end of the plug using a screwdriver.
    • Take both of the holding screws, and unscrew them just about halfway from the hole. This will be enough of a gap for you to hook your wires into.
    • For convenience, take note of the screw turning towards you when loosened. Once the wires are hooked in, we will need to put them in the opposite direction so that the wires are pulled into and secured to the holding screw.
  7. Vintage Plug Replacement: stap 7, afbeelding 1 van 3 Vintage Plug Replacement: stap 7, afbeelding 2 van 3 Vintage Plug Replacement: stap 7, afbeelding 3 van 3
    • Take your pair of pliers, specifically non cutting pliers and clamp down on the metal ends of the wires and gently twist them until they are connected and thinner as seen in Photo 2.
    • With our holding screws primed, turn your pliers so that the wire makes a hook like shape as seen in Photo 3. Then tighten your holding screws again around each wire as indicated by the red circle.
    • As mentioned in Step 6, the direction the screw needs to be turned to tighten is away from you, so hook the wire into the bottom of the screw so that the tips are pointing towards you. See Photo 3 for the direction it should go.
    • For older wires like this, it is not necessary to connect a specific wire to ground or neutral, as in this case, older wires often did not have this, so they can be connected to either screw.
  8. Vintage Plug Replacement: stap 8, afbeelding 1 van 2 Vintage Plug Replacement: stap 8, afbeelding 2 van 2
    • Take your casing screws and screw them back on, bringing the casing back up to meet the plug. Tightly screw into the casing until the plug is firmly held into place.
    • Congratulations! You have taken apart an old plug, and replaced it with a new one. While this last part is optional, you can test this plug in an outlet, preferably closest to where it would be used most.
Conclusie
At the end of this guide you will have been able to successfully learn how to cut, strip, and replace an old wire and plug with a new one!
Conner Spangler
211 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 436
