Inleiding
Learn how to remove the clogged old screen, deep clean grouphead and install new screen and gasket.
Wat je nodig hebt
Use Joe Glo coffee cleaner and hot water to soak the grouphead for 10-15 minutes.
Use a small flathead to clean the bottom surface of the grouphead.
A small stainless steel brush works well. They can be found at your local hardware store.
Use a paper towel / regular towel to soak the dirty water from the grouphead.
Use the compressed air can to clean any excess water or coffee.
Last but not least, use the pick on the top and bottom rails to remove last bits of coffee debris.
Take the new gasket and install it with the lettering down.
Use a 1/4 inch flat punch to push down the gasket to ensure its nice and flat.
Insert the diffuser with the water channels facing down.
Careful not to over tighten and break screw. It will be extremely difficult to remove.
9 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Perfect - Just what I needed for my machine.
very well done. going to do it with my silvia this weekend.
Great!!! I’m assuming the fully assembled backflush procedure is unnecessary after this. But I was wondering if there are any hidden crevices that backflush would get to. This is more serious than you think in my case… I’m resurrecting a rarely used, 15 year old V1 that has NEVER been serviced.
