Inleiding
The Vicks FilterFree Plus is a handy device for humidifying air, but it may be necessary to replace the reservoir cap if it becomes damaged or worn. Replacing the cap is a simple process that requires just a few steps. Before starting, it is important to make sure that the device is completely free of water to avoid spills during replacement. In the following guide, we will outline the steps needed to remove and replace the Vicks FilterFree Plus reservoir cap. Be sure to follow each step carefully to ensure proper execution and operation of the device.
Orient the device so the nozzle is facing the ceiling.
Twist off the primary water holding cap.
