Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
Carefully remove the battery from the phone by prying the battery from the top.
Remove the rubber plugs from the screw holes around the screen with the opening tool.
Remove the four screws from around the phone's screen with a Phillips screwdriver.
Pry the top cover off the phone with a plastic opening tool.
Pry the circuit board off of the screen with the opening tool.
