Ga door naar hoofdinhoud
Verizon M1424WR Motherboard Replacement
Wat je nodig hebt
  1. Verizon M1424WR Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: stap 2, afbeelding 1 van 3 Verizon M1424WR Motherboard Replacement: stap 2, afbeelding 2 van 3 Verizon M1424WR Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: stap 3, afbeelding 1 van 2 Verizon M1424WR Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: stap 4, afbeelding 1 van 2 Verizon M1424WR Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: stap 5, afbeelding 1 van 3 Verizon M1424WR Motherboard Replacement: stap 5, afbeelding 2 van 3 Verizon M1424WR Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull the circuit board towards you until it is separate from the bottom casing.
Conclusie
Jeffrey Fox
347 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 762
