Ga door naar hoofdinhoud
Inleiding
What you can expect from this guide is a step by step process on how to remove the LCD display screen on a Verizon Ellipsis Jetpack MHS800L.
Onderdelen
Geen onderdelen opgegeven.
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: stap 1, afbeelding 1 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: stap 1, afbeelding 2 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: stap 1, afbeelding 3 van 3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 2, afbeelding 1 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 2, afbeelding 2 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 2, afbeelding 3 van 3
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Philips #00 screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool at the seams and pry open the case.
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 5, afbeelding 1 van 1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: stap 6, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: stap 6, afbeelding 2 van 2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 7, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 7, afbeelding 2 van 2
    • With a pair of ESD Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 8, afbeelding 1 van 1
    • After removing the tape you may use the ESD Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 9, afbeelding 1 van 1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: stap 10, afbeelding 1 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: stap 10, afbeelding 2 van 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: stap 10, afbeelding 3 van 3
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 11, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 11, afbeelding 2 van 2
    • Using the ESD Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 12, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: stap 12, afbeelding 2 van 2
    • Gently insert the ESD Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Richard J Porras
504 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-3, Baechle Spring 2016 Lid van IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Leden
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,005
