Ga door naar hoofdinhoud
Verizon Ellipsis Jetpack MHS800L Battery Replacement
Wat je nodig hebt
  1. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: stap 1, afbeelding 1 van 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: stap 1, afbeelding 2 van 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: stap 1, afbeelding 3 van 3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 2, afbeelding 1 van 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 2, afbeelding 2 van 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Phillips #00 Screwdriver
    $5.49
    Koop
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 4, afbeelding 1 van 1
    iFixit Opening Picks (Set of 6)
    Koop
  5. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 5, afbeelding 1 van 1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: stap 6, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 7, afbeelding 1 van 2 Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 7, afbeelding 2 van 2
    Koop
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 8, afbeelding 1 van 1
    Koop
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Battery Replacement: stap 9, afbeelding 1 van 1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Richard J Porras
504 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-3, Baechle Spring 2016 Lid van IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Leden
6 handleidingen geschreven
5 opmerkingen
I'd like to let you know that after step 9, it is possible to unwrap the battery and break loose the circuit board on the battery. At which point you can reinstall the circuit board in the router with no battery attached. This makes the Jetpack plug-in only which is all I need it for anyways. It was a great and free fix for my swollen battery.
Thanks for the article!
Jeff Lovett - Antwoord
Opps, I think that steps 3 & 4 have been reversed. You can't get to the "3 additional screws" until you're looking at the red cover which is below the black cover that needs to be pried off first.
Otherwise, the process seems to be going well.
bevrievley - Antwoord
It’s unclear. Once you unscrew that first screw, you have to remove the TOP black portion (the picture looks like you’re removing the bottom). Once you remove that top portion, the red plastic is exposed, revealing the three other screws.
imsonnyburnett -
And -- continuing with step 5, there are some plastic "snap" locks between the red and black covers -- 5 by my count, 2 along each of the long edges, 1 along the charging port edge. Always good to pry carefully.
Once apart, battery is on bottom and can be easily removed/replaced as per steps 7 & 8.
now how do we FORCE a factory data reset without the admin password?
baily jacoby - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 7,694
